Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly. Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive. Grasp one of the battery adhesive tabs with your fingers and slowly pull it away from the battery, towards the bottom of the phone.
  • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
  • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
  • Grasp one of the battery adhesive tabs with your fingers and slowly pull it away from the battery, towards the bottom of the phone.
  • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the midframe. For best results, pull the strip at as low an angle as possible, without snagging it on any other components.
  • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strip, and then proceed with the rest of the steps.
Versuche die Klebestreifen glatt und faltenlos zu halten, da verdrehte oder verknitterte Klebestreifen zusammenkleben und reißen, statt sich leicht entfernen zu lassen.
Vermeide es auch, beim Herausziehen der Klebestreifen auf den Akku zu drücken, da sonst die Klebestreifen durch den Druck hängen bleiben und reißen können.
Fasse eine der Akku-Klebelaschen mit den Fingern und ziehe sie langsam vom Akku weg in Richtung Unterkante des iPhones.
Ziehe gleichmäßig und mit konstanter Spannung am Klebestreifen, bis er zwischen Akku und rückseitigem Gehäuse herausrutscht. Das gelingt am Besten, wenn du den Klebestreifen in einem möglichst flachen Winkel herausziehst, jedoch ohne dass er sich an anderen Bauteilen des iPhones verfängt.
Der Klebestreifen wird sich auf ein Vielfaches seiner ursprünglichen Länge dehnen. Ziehe immer weiter und fasse, falls nötig, den Klebestreifen am Akku nach.
Wenn die Akku-Klebelasche bei diesem Verfahren reißen sollte, dann hole das restliche Stück des Klebestreifens mit den Fingern oder einer stumpfen Pinzette heraus und mache mit dem Ziehen weiter.
Wenn einer der Klebestreifen unter dem Akku abreißt und nicht mehr herausgeholt werden kann, entferne zuerst den anderen Klebestreifen und fahre dann wie im Folgenden beschrieben fort.
