Zum Hauptinhalt wechseln
Englisch
Deutsch
35. Schritt
Use a spudger to pry the metal rings on the battery terminals up so that they perpendicular to the battery terminals. These rings should be on the same end as the surface mount leads. If they are on opposite ends, the board is on backwards, and you'll need to unscrew the nuts, rotate the circuit board 180°, reinstall the nuts, and tighten the two screws.
  • Use a spudger to pry the metal rings on the battery terminals up so that they perpendicular to the battery terminals.
  • These rings should be on the same end as the surface mount leads. If they are on opposite ends, the board is on backwards, and you'll need to unscrew the nuts, rotate the circuit board 180°, reinstall the nuts, and tighten the two screws.
Hier Übersetzung einfügen
