Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 6
(A1270) Lift the optical drive from the thick side, then pull out. (A1379) You will need to be even more careful with this model, as there is less wiggle room. Peel back the insulation tape to see the connector.
  • (A1270) Lift the optical drive from the thick side, then pull out.
  • (A1379) You will need to be even more careful with this model, as there is less wiggle room. Peel back the insulation tape to see the connector.
  • Be careful of the wires still running from the drive to case.
  • When re-installing the optical drive insert tongue in groove side first, as pictured.
Hier Übersetzung einfügen
