Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 6
there you have it. The destroyed burnt TRIAC with cables and aluminium-cooling. This one broke at the housing, look at the red arrow. The pins are bent directly at the housing, so this destruction occured at the montage of the triac ! bad. :( The current let it explode and damaged it complete. cables look ok, platine is ok too. It looks burnt, but this is only black smoke.
  • there you have it. The destroyed burnt TRIAC with cables and aluminium-cooling.
  • This one broke at the housing, look at the red arrow. The pins are bent directly at the housing, so this destruction occured at the montage of the triac ! bad. :( The current let it explode and damaged it complete.
  • cables look ok, platine is ok too. It looks burnt, but this is only black smoke.
  • Now we have to drill out that part...
Hier ist der durchgebrannte Triac auf dem Aluminiumkühler gut zu sehen.
Der Triac ist direkt am Gehäuse durchgebrannt, möglicherweise weil er unter mechanischer Spannung stand, schlecht.
Die Platine ist zwar angekokelt, die Verbindungen sehen aber gut aus.
Jetzt muss das Teil ausgebohrt werden...
