Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 24 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
  • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
  • One 2.9 mm screw
  • One 2.2 mm screw
  • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
Entferne die beiden folgenden Kreuzschlitz Schrauben von der Kabelabdeckung des Akkuanschlusses.
Eine 2,9 mm Schraube
Eine 2,2 mm Schraube
[* black] Remove the two Phillips screws securing the battery connector bracketbracket, of the following lengths:
[* red] One 2.9 mm screw
[* orange] One 2.2 mm screw
[* icon_note] Throughout this repair, [product|IF145-167-4|keep track of each screw|new_window=true] and make sure it goes back exactly where it came from to avoid damaging your iPhone.
