Englisch
Deutsch
6. Schritt
Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive. Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive. Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive.
  • Insert the flat end of a spudger between the Lightning connector assembly and rear case to break up the remaining adhesive.
Schiebe das flache Ende eines Spudgers zwischen die Lightning Connector Einheit und das hintere Gehäuse, um den restlichen Kleber zu lösen.
