Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
5. Schritt
Remove the following Phillips screws securing the speaker to the rear case:
  • Remove the following Phillips screws securing the speaker to the rear case:
  • Two 2.6 mm screws
  • Two 2.3 mm screws
  • Do not mix these screws together. They are slightly different from each other!
  • One 3.0 mm screw
Entferne folgende Kreuzschlitzschrauben, welche den Lautsprecher am Rückgehäuse befestigen:
Zwei 2,6 mm Schrauben
Zwei 2,3 mm Schrauben
Eine 3,0 mm Schraube
[* black] Remove the following Phillips screws securing the speaker to the rear case:
[* red] Two 2.6 mm screws
[* orange] Two 2.3 mm screws
[* icon_note] Do not mix these screws together. They are slightly different from each other!
[* yellow] One 3.0 mm screw
