Englisch
Deutsch
Schritt 1 übersetzen
Step 1
Unplug your grinder before completing this repair to avoid electric shock. Remove the hopper and take the upper burrs out. Empty out any coffee grounds (An air gun or vacuum helps) and then inspect the impeller blades.
Inspect your grinder impeller
  • Unplug your grinder before completing this repair to avoid electric shock.
  • Remove the hopper and take the upper burrs out. Empty out any coffee grounds (An air gun or vacuum helps) and then inspect the impeller blades.
  • If the impeller can fit through the hole (ie: be removed just by taking out the lower burr) then it definitely needs replacement.
  • A good impeller should not be removable without dis-assembly and the tips of the impeller blades should not be visible.
  • If your impeller is made of stainless steel rather than plastic you likely have a newer model with significant design changes (eg: BCG820). Stainless steel should not wear out and so your problem is elsewhere.
Hier Übersetzung einfügen
