Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6
Be careful when flipping up the logic board. The headphone jack and docking port are attached to the board. Gently lift the logic board (and attached components) upward. The smaller portion of the logic board that resides underneath is very bendable and frail. Make sure not to pull the spudger upward when using it to detach the small board. Use only side-to-side movement.
  • Be careful when flipping up the logic board. The headphone jack and docking port are attached to the board.
  • Gently lift the logic board (and attached components) upward.
  • The smaller portion of the logic board that resides underneath is very bendable and frail. Make sure not to pull the spudger upward when using it to detach the small board. Use only side-to-side movement.
  • Slide the spudger under the small portion of the logic board. The board should come loose once the spudger has slid almost all the way to the other side.
Hier Übersetzung einfügen
