Englisch
Deutsch
Schritt 9 übersetzen
9. Schritt
Carefully separate the face of the phone from the LCD screen by using a spudger or a pry pick. Replace the broken LCD or digitizer and reassemble in reverse. If replacing the digitizer, you may either replace the entire front as part of an assembly or use a heat gun to separate and replace the glass only.
  • Carefully separate the face of the phone from the LCD screen by using a spudger or a pry pick.
  • Replace the broken LCD or digitizer and reassemble in reverse.
  • If replacing the digitizer, you may either replace the entire front as part of an assembly or use a heat gun to separate and replace the glass only.
Hier Übersetzung einfügen
