Englisch
Deutsch
18. Schritt
Insert the dipstick back into the hole. Press it all the way in, then remove it. There should be a thin layer of oil up to the bump on the dipstick labeled "MAX."
  • Insert the dipstick back into the hole. Press it all the way in, then remove it.
  • There should be a thin layer of oil up to the bump on the dipstick labeled "MAX."
  • The bump indicates the maximum amount of oil that should be in the tank while the twist at the end indicates the minimum amount. Anywhere in the cross-hatched middle area is sufficient.
  • After checking if the oil level is too high or too low, you can add or remove oil accordingly.
Hier Übersetzung einfügen
