Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
13. Schritt
Use tweezers to carefully pull the upper button assembly ribbon cable straight out of its connector. There is very little give on this cable, so you may need to apply a decent amount of force. Be sure you are pulling the cable straight back, and not upward against the connector.
  • Use tweezers to carefully pull the upper button assembly ribbon cable straight out of its connector.
  • There is very little give on this cable, so you may need to apply a decent amount of force. Be sure you are pulling the cable straight back, and not upward against the connector.
Hier Übersetzung einfügen
