Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
15. Schritt
Use a pair of tweezers to peel up the tape securing the right Wi-Fi antenna cable near the SIM board. Peel carefully and pull up on the tape only—not the antenna cable, which will rip easily. It may be helpful to fold the SIM board cable back slightly to better access the tape—but be careful not to damage the SIM board cable. If you need more clearance, remove the SIM board.
  • Use a pair of tweezers to peel up the tape securing the right Wi-Fi antenna cable near the SIM board.
  • Peel carefully and pull up on the tape only—not the antenna cable, which will rip easily.
  • It may be helpful to fold the SIM board cable back slightly to better access the tape—but be careful not to damage the SIM board cable. If you need more clearance, remove the SIM board.
Hier Übersetzung einfügen
