Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
20. Schritt
Continue peeling up the tape away until there is enough slack in the left speaker cable to disconnect it. Do not completely remove the tape—it will be easier to replace if you leave a section still attached to the rear case.
  • Continue peeling up the tape away until there is enough slack in the left speaker cable to disconnect it.
  • Do not completely remove the tape—it will be easier to replace if you leave a section still attached to the rear case.
Hier Übersetzung einfügen
