Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 13
Grab the excess wire with your tweezers, and bending back and forth, gently snap it off. Repeat the same procedure for the other end. If you break your solder joint by twitching the leftover wire carefully back and forth, the joint was too weak to begin with. If you break your solder joint by twitching the leftover wire carefully back and forth, the joint was too weak to begin with.
Removing the excess wire
  • Grab the excess wire with your tweezers, and bending back and forth, gently snap it off. Repeat the same procedure for the other end.
  • If you break your solder joint by twitching the leftover wire carefully back and forth, the joint was too weak to begin with.
Hier Übersetzung einfügen
