Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 7
Eventually you will end up with the string of LEDs that are the backlight at the top. They are only glued into place with mild adhesive and can be removed quite easily. Just avoid cutting into the backlight strip.
The backlight strip
  • Eventually you will end up with the string of LEDs that are the backlight at the top. They are only glued into place with mild adhesive and can be removed quite easily. Just avoid cutting into the backlight strip.
  • If you do ruin the LED strip, you will at least be able to salvage some fairly bright but energy efficient SMD LEDs for future tinkering.
  • In this picture you can also see how much dust there actually can be on the layers. Always blow a bit of pressured air at the parts when reassembling
Hier Übersetzung einfügen
