Englisch
Deutsch
Schritt 15 übersetzen
15. Schritt
Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged. Place your old oil filter face down in your oil drain pan and allow 12-24 hours for all the oil to drain out.
  • Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged.
  • Place your old oil filter face down in your oil drain pan and allow 12-24 hours for all the oil to drain out.
  • Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
Starte das Fahrzeug und suche unter dem Auto nach Lecks. Bei festgestellten Undichtigkeiten, solltest du das Fahrzeug abstellen und die Ablassschraube und den Filter kontrollieren, ob diese angezogen werden müssen, oder ob ein Teil beschädigt ist.
Lege den Ölfilter für 12-24h mit der Oberseite nach unten in die Ablasswanne, um das Öl vollständig auslaufen zu lassen.
Bring dein altes Öl und den alten Ölfilter zu einem Recycling-Hof.
