Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 26 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
5. Schritt
Rotate the computer 90 degrees clockwise so the ports face you.
  • Rotate the computer 90 degrees clockwise so the ports face you.
  • Remove the three 3 mm Phillips screws along the edge of the lower case.
  • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Hier Übersetzung einfügen
