Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 17 übersetzen
Schritt 17
Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged. After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
  • Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged.
  • After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
  • Allow 12-24 hours for all the oil to drain out of your old oil filter.
  • Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
Starte das Auto und suche nach Lecks unter dem Auto. Schalte bei undichten Stellen das Fahrzeug aus und finde heraus, ob die Ablassschraube oder der Filter angezogen werden müssen, oder ob ein Teil beschädigt wurde.
Nachdem der Motor einige Minuten lang in Betrieb war, muss er mindestens eine Stunde lang abkühlen und der Ölstand muss erneut überprüft werden. Wenn der Ölstand mehr als 1/2" über der oberen Bohrung des Messstabes liegt, musst du Öl ablassen. Wenn der Ölstand unter der unteren Bohrung des Messstabes liegt, musst du Öl nachfüllen.
Lasse 12-24 Stunden lang das gesamte Öl aus deinem alten Ölfilter ablaufen.
Bringe dein altes Öl und deinen alten Filter zu einer Recyclinganlage. Die meisten Kfz-Teilehändler und Werkstätten akzeptieren diese kostenlos. Darüber hinaus haben einige Städte und/oder Landkreise einen Service, bei dem sie Altöl und Filter von zu Hause abholen.
