Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
After disconnecting the plastic connector plate from the main body, you can see that the cable is hooked and looped around the orange handle. Pull the cable towards the handle to allow the wire to become loose.  This will give you enough room to remove the hook.
  • After disconnecting the plastic connector plate from the main body, you can see that the cable is hooked and looped around the orange handle.
  • Pull the cable towards the handle to allow the wire to become loose. This will give you enough room to remove the hook.
Hier Übersetzung einfügen
