Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 6
If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD. If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD. If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
  • If you want to change only the glass, disconnect the touch screen flex cable and gently separate the glass from the LCD.
Wenn du nur das Glas tauschen willst, dann trenne das Touchscreen-Kabel und löse das Glas vorsichtig (!) vom LCD.
