Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 17 übersetzen
Schritt 17
Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged. After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
  • Start the car and look for leaks under the car. If there are leaks, shut the car off and determine if the drain plug or filter need to be tightened, or if a part has been damaged.
  • After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
  • Allow 12-24 hours for all the oil to drain out of your old oil filter.
  • Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
Starte den Wagen und schau am Unterboden nach Leckagen. Falls Du welche findest, schalte den Motor ab. Sieh nach ob die Ablassschraube oder der Filter nachgezogen werden müssen oder oben Teil beschädigt wurde.
Nachdem der Motor für einige Minuten gelaufen ist, lasse ihn mindestens eine Stunde lang abkühlen und prüfe den Ölstand erneut. Ist der Ölstand höher als ca. 12 mm oberhalb des oberen Lochs musst du Öl ablassen. Ist er unterhalb des unteren Lochs musst du welches auffüllen.
Warte 12-24 Stunden bis sich der alte Filter ganz leer ist.
Bringe dein altes Öl und deinen Filter zu einer Recyclingeinrichtung. Viele Autoersatzteilläden und Werkstätten nehmen das kostenlos an. Zusätzlich bieten manche Städte/Landkreise die Möglichkeit gebrauchtes Öl und Filter zu Hause abholen zu lassen.
