Englisch
Deutsch
6. Schritt
Make sure you are wearing clean gloves, then dip your finger into the new oil and evenly rub a thin layer of oil around the rubber gasket of the new oil filter. Use a clean rag or towel to wipe down the oil filter threads and contact area on the engine. Use your hand to screw the new filter back into place over the oil filter threads. Hand-tighten it until it is snug.
  • Make sure you are wearing clean gloves, then dip your finger into the new oil and evenly rub a thin layer of oil around the rubber gasket of the new oil filter.
  • Use a clean rag or towel to wipe down the oil filter threads and contact area on the engine.
  • Use your hand to screw the new filter back into place over the oil filter threads. Hand-tighten it until it is snug.
  • Remove the oil drain pan and any other tools from underneath the car.
Stelle sicher, dass deine Handschuhe sauber sind, tunke deinen Finger in das neue Öl und bestreiche die Dichtung des neuen Filters mit einer dünnen Schicht frischen Öls.
Säubere das Ölfiltergewinde und die Kontaktstellen am Motor mit einem sauberen Lappen oder Handtuch.
Schraube den neuen Filter über dem Ölfiltergewinde von Hand zu, bis er fest sitzt.
Entferne die Ölauffangwanne und alle anderen Werkzeuge unter dem Auto.
