Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 13
Install the new bold sled assembly, plunger tube and all, back into the gun. Be careful with the trigger lock. You may have to remove it and reinstall it. Make sure you put it back exactly how you found it. The hole in the bolt sled should drop right into the plastic peg on the cocking mechanism.
Install bolt sled assembly.
  • Install the new bold sled assembly, plunger tube and all, back into the gun.
  • Be careful with the trigger lock. You may have to remove it and reinstall it. Make sure you put it back exactly how you found it.
  • The hole in the bolt sled should drop right into the plastic peg on the cocking mechanism.
  • Make sure the tabs on the plunger tube are in the guide rails on the outer shell of the blaster.
Hier Übersetzung einfügen
