Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 18
Due to a tiny mistake in my batch of kits, the front of the breech will block the top of the magazine from inserting all the way. Check the fit in your blaster before you do this step. It's an easy fix that won't affect the use of the modified magazine in your other blasters. Using a rotary tool or file, grind down the back corner of the top of the magazine.
Modify your magazines.
  • Due to a tiny mistake in my batch of kits, the front of the breech will block the top of the magazine from inserting all the way. Check the fit in your blaster before you do this step.
  • It's an easy fix that won't affect the use of the modified magazine in your other blasters.
  • Using a rotary tool or file, grind down the back corner of the top of the magazine.
  • Keep grinding and testing the fit in your blaster. You don't need to take off much.
  • Make sure you are grinding down the correct corner! It should be the corner closest to the rear end of your darts when loaded correctly.
Hier Übersetzung einfügen
