Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off. Insert a SIM card eject tool or a  paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
  • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
  • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
  • Push the tool into the hole until you see the card pop out.
Führe ein SIM Card Eject Tool in das kleine Loch neben dem SIM Kartenslot, direkt unter dem Ein-/Ausschalter.
Drücke das Sim Card Eject Tool in das Loch hinein, bis der Kartenhalter herauskommt.
[* icon_note] Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
black] Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
[* black] Push the tool into the hole until you see the card pop out.
