Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Turn off the power and remove the battery before working on your Eee PC
  • Turn off the power and remove the battery before working on your Eee PC
  • Start by removing the keyboard
  • There are four latches on the top of the keyboard, use a paper clip or other object to disengage the latches
  • You may have to pull the keyboard up enough with the object - there is no spring mechanism to pop the keyboard out. One trick is after lifting it enough, to slide it (not too much) upward to remove the bottom side.
  • The keyboard assembly has also two plastic retention points on the sides, and some thermal tape sticking the keyboard down.
  • Caution: the keyboard has a ribbon connector underneath it which must be carefully unplugged before fully removing the keyboard.
Hier Übersetzung einfügen
