Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
2. Schritt
Disconnect the fuel level sensor connector, located near the tank hinge base. It will be a three wire connector and one side of the wire will be traceable to the underside of the tank. Carefully lift the front of the tank to gain access to the hoses attached to the tank. Do not lift the tank too much, or you risk damaging fuel lines, vacuum lines and spilling fuel.
  • Disconnect the fuel level sensor connector, located near the tank hinge base. It will be a three wire connector and one side of the wire will be traceable to the underside of the tank.
  • Carefully lift the front of the tank to gain access to the hoses attached to the tank.
  • Do not lift the tank too much, or you risk damaging fuel lines, vacuum lines and spilling fuel.
  • There are small metal inserts that go into the front tank mounts. Make sure these do not fall out and get lost while working with the tank.
Hier Übersetzung einfügen
