Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 4 übersetzen
4. Schritt
Carefully lift the tank up and off the frame of the bike, being sure that the fuel level sensor wire does not get caught in the frame. When you set your tank aside, be mindful of the petcock hose fittings, especially the vacuum fitting on the bottom. These fittings can easily be broken by the weight of the tank and are costly to replace.
  • Carefully lift the tank up and off the frame of the bike, being sure that the fuel level sensor wire does not get caught in the frame.
  • When you set your tank aside, be mindful of the petcock hose fittings, especially the vacuum fitting on the bottom. These fittings can easily be broken by the weight of the tank and are costly to replace.
Hier Übersetzung einfügen
