Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
2. Schritt
Locate the 10 mm hex coolant drain plug. It is on the right engine cover, just below the coolant outlet. Turn the coolant drain plug counter-clockwise with a 10 mm socket wrench or box end wrench until it can be turned freely by hand. Place a container under the drain plug to catch the coolant when it streams out of the coolant drain hole.
  • Locate the 10 mm hex coolant drain plug. It is on the right engine cover, just below the coolant outlet.
  • Turn the coolant drain plug counter-clockwise with a 10 mm socket wrench or box end wrench until it can be turned freely by hand.
  • Place a container under the drain plug to catch the coolant when it streams out of the coolant drain hole.
  • Coolant capacity is 1.7L, ensure your container can accommodate this.
  • If you are not using a pan style container, it is recommended that you use a funnel to help prevent spills.
Hier Übersetzung einfügen
