Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 4 übersetzen
4. Schritt
Put the coolant drain plug back in its hole and turn it clockwise with a socket wrench or box end wrench until it is snug. Do not over-tighten the drain plug or you risk stripping the threads. Suzuki rates the drain plug torque at 9.5 lb-ft (13 N-m). Place the radiator cap back over the filler hole and turn it clockwise until is snug.
  • Put the coolant drain plug back in its hole and turn it clockwise with a socket wrench or box end wrench until it is snug.
  • Do not over-tighten the drain plug or you risk stripping the threads. Suzuki rates the drain plug torque at 9.5 lb-ft (13 N-m).
  • Place the radiator cap back over the filler hole and turn it clockwise until is snug.
  • Placing the radiator cap back on the radiator will prevent debris from entering the radiator while working on the bike.
Hier Übersetzung einfügen
