Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers. Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot.  Once you are hooked behind the boot, pull outwards. This will reveal two small Phillips-head screws.  Remove them.
  • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
  • Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
  • This will reveal two small Phillips-head screws. Remove them.
  • Keep these two screws together.
Hier Übersetzung einfügen
