Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Use a Phillips head screwdriver to remove the two larger screws. The two smaller screws (orange) were a little tricky. They are screwed down very tight. I started with a #0 phillips head and slightly stripped the screw head. Not enough to destroy it. I recommend using a #1 phillips head on these. I also used a small rubber grip in order to get a better grip on my screwdriver. Made it much easier. Once screws are removed lift the plastic frame from the left side and remove it from the top of the power brick and flip it over.
Remove Screws
  • Use a Phillips head screwdriver to remove the two larger screws.
  • The two smaller screws (orange) were a little tricky. They are screwed down very tight. I started with a #0 phillips head and slightly stripped the screw head. Not enough to destroy it. I recommend using a #1 phillips head on these. I also used a small rubber grip in order to get a better grip on my screwdriver. Made it much easier.
  • Once screws are removed lift the plastic frame from the left side and remove it from the top of the power brick and flip it over.
  • Unlike the X360 power brick, the light diffuser does not need to be removed from the power supply. If you want to remove it anyway simply grab it with your fingers and lift it out.
  • When I used a can of air duster to clean the inside, the smaller metal sheet (left side) immediately blew out. If this happens don't panic. There's tape on the bottom side. Simply put it back in with a little pressure to hold it down and you're good to go.
  • These screws serve no purpose. There was nothing under there. Unless you have a different variation than mine there is no need to remove these screws.
Entferne die beiden größeren Schrauben mit einem Kreuzschlitzschraubendreher.
Die beiden kleineren Schrauben (orange) sind sehr fest angezogen. Ich empfehle einen #1 Kreuzschlitzschraubendreher, um sie zu lösen. Wenn die Köpfe der Schrauben kaputt gehen sollten, kann ein Gummiband zwischen Schraubenkopf und Schraubendreher helfen, etwas mehr Halt zu bekommen.
Wenn diese Schrauben entfernt sind, greife die schwarze Plastikrahmen an der linken Seite und nimm ihn aus dem Oberteil des Netzteiles heraus und drehe ihn um.
Anders als bei beim Xbox 360 Netzteil, muss der Lichtdiffusor nicht herausgenommen werden. Wenn du ihn jedoch trotzdem herausnehmen möchtest, kannst du ihn einfach mit den Fingern herausnehmen.
Als ich mit einem Druckluftreiniger das Gehäuse gereinigt habe, hat sich die kleinere der beiden Metallplatten gelöst. Keine Panik! Es hat Klebeband auf der Unterseite und kann einfach wieder festgeklebt werden.
Diese Schrauben haben keinen Nutzen. Bei meinem Modell war unter diesen Schrauben nichts. Es sei denn du hast eine andere Variante, ist es unnötig diese Schrauben zu entfernen.
