Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Remove the two 8.2 mm T6 Torx screws securing the hard drive retaining bracket to the lower case. Use a spudger if the hard drive ribbon cable is firmly glued to the top of the drive. You might have to work slowly in order to not damage it. Lift the hard drive retaining bracket up and out of the computer.
  • Remove the two 8.2 mm T6 Torx screws securing the hard drive retaining bracket to the lower case.
  • Use a spudger if the hard drive ribbon cable is firmly glued to the top of the drive. You might have to work slowly in order to not damage it.
  • Lift the hard drive retaining bracket up and out of the computer.
  • Lift up the hard drive with one hand and use your other hand to disconnect the hard drive cable.
Hier Übersetzung einfügen
