Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 17 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
22. Schritt
Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad. Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath. Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath.
  • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
  • Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath.
Schiebe das linke Plektrum an der Unterkante des Displays entlang und entferne es dann von der rechten unteren Ecke des iPads.
Sei hier besonders vorsichtig und stecke das Plektrum nicht tiefer als ca 7 mm hinein, um Schäden am Home Button und den Displaykabeln darunter zu vermeiden.
[* black] Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
[* icon_caution] Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath.
