Zum Hauptinhalt wechseln
Englisch
Deutsch
8. Schritt
Peel up the two remaining pieces of grounding tape attaching the left antenna to the rear case, as done in the previous steps. Upon reassembly, it is important to reattach the antenna cables to the motherboard at all four taped locations with grounding tape properly adhered on the copper strip underneath. Upon reassembly, it is important to reattach the antenna cables to the motherboard at all four taped locations with grounding tape properly adhered on the copper strip underneath.
  • Peel up the two remaining pieces of grounding tape attaching the left antenna to the rear case, as done in the previous steps.
  • Upon reassembly, it is important to reattach the antenna cables to the motherboard at all four taped locations with grounding tape properly adhered on the copper strip underneath.
Löse so wie in den vorigen Schritten die beiden verbleibenden Stücke des Erdungsbands, die die linke Antenne am Gehäuse festhalten.
Achte beim Wiederzusammenbau sehr darauf, dass die Antennenkabel an allen vier Stellen wieder gut mit Erdungsband auf dem Kupferstreifen darunter befestigt werden.
