Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Remove the following screws: 7.5 mm Phillips screws (2) that secure the motherboard to the bottom panel. The screw on the top right will also be attached to a grounding wire, it is okay to remove this screw.
  • Remove the following screws:
  • 7.5 mm Phillips screws (2) that secure the motherboard to the bottom panel. The screw on the top right will also be attached to a grounding wire, it is okay to remove this screw.
  • Remove the 7.5 mm Phillips screw on the bottom right that attaches the grounding wire to the disc tray.
  • 7.5 mm Phillips screws (4) on outside of player near input/output plugs.
Hier Übersetzung einfügen
