Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Remove the two 8.2 mm T6 Torx screws securing the hard drive retaining bracket to the lower case. Use a spudger if the hard drive ribbon cable is firmly glued to the top of the drive. You might have to work slowly in order to not damage it. Lift the hard drive retaining bracket up and out of the computer.
  • Remove the two 8.2 mm T6 Torx screws securing the hard drive retaining bracket to the lower case.
  • Use a spudger if the hard drive ribbon cable is firmly glued to the top of the drive. You might have to work slowly in order to not damage it.
  • Lift the hard drive retaining bracket up and out of the computer.
  • Lift up the hard drive with one hand and use your other hand to disconnect the hard drive cable.
Hier Übersetzung einfügen
