Zum Hauptinhalt wechseln
Englisch
Deutsch
4. Schritt
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too warm to touch comfortably. Overheating the iPhone may ignite the battery.
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. It should be slightly too warm to touch comfortably.
  • Overheating the iPhone may ignite the battery.
  • Flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
  • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
  • Do not pry against the logic board or you may damage the phone.
  • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
  • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
  • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
Wenn einer der Klebestreifen abgerissen ist und der Akku weiterhin im Rückgehäuse festklebt, erhitze einen iOpener, oder benutze einen Haatrockner, um das Rückgehäuse direkt hinter dem Akku zu erhitzen. Es sollte so heiß werden, dass du es kaum noch anfassen kannst.
Ein Überhitzen des iPhones könnte den Akku in Brand setzen.
Drehe das iPhone um und trenne die Klebeverbindungen hinter dem Akku mit einer Plastikkarte auf.
Setze die Karte nicht in den Bereich zwischen der Lautstärke leiser - Taste und der Oberkante des Akkus ein. Das Kabel für die Lautstärkeregelung liegt darunter und könnte beschädigt werden.
Hebele nicht gegen das Logic Board, das könnte das iPhone beschädigen.
Halte die Karte so flach wie möglich und vermeide es, den Akku zu verbiegen. Das könnte ihn beschädigen und gefährliche Chemikalien freisetzen, oder ihn in Brand setzen. Benutze keinesfalls irgendwelche scharfen Werkzeuge.
Als Alternative kannst du den Akku auch mit einem Stück Zahnseide vom Gehäuse trennen. Noch kräftiger als Zahnseide ist eine Gitarrensaite, etwa eine 0,009 E Saite aus einem 12 Saiten Set.
Ziehe die Saite oder die Zahnseide unter den oberen Ecken des Akkus durch, bringe beide Enden zusammen, wickle sie um ein gefaltetes Tuch und ziehe gleichmäßig.
