Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Remove the faulty EM10 filter.  Use a soldering iron to melt the solder and gently lift off the filter with tweezers or pliers, being careful not to pull the copper tracks off the motherboard. A replacement EM10 filter is available HERE  (as at 01/01/12) no doubt other suppliers exist Solder new EM10 filter into place, ensuring correct orientation.  If required, check the new filter with a multimeter to confirm before installing.
  • Remove the faulty EM10 filter. Use a soldering iron to melt the solder and gently lift off the filter with tweezers or pliers, being careful not to pull the copper tracks off the motherboard.
  • A replacement EM10 filter is available HERE (as at 01/01/12) no doubt other suppliers exist
  • Solder new EM10 filter into place, ensuring correct orientation. If required, check the new filter with a multimeter to confirm before installing.
  • Alternate method - Bridge the solder pads that correspond with each set of pads - yellow to yellow and cyan to cyan
  • Bypassing the EM10 filter may affect the system performance and is not recommended
Hier Übersetzung einfügen
