Zum Hauptinhalt wechseln
Englisch
Deutsch
7. Schritt
Carefully insert the cable from your old trackpad through its slot cut into your new upper case. Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
  • Carefully insert the cable from your old trackpad through its slot cut into your new upper case.
  • Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
  • Pull the trackpad cable as you seat the trackpad into its void in your new upper case.
Hier Übersetzung einfügen
