Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Use the nylon spudger to pry the back casing near the hinges for the screen. Continue to pry along the edge of the back case until the back is ready to be removed. Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  • Use the nylon spudger to pry the back casing near the hinges for the screen.
  • Continue to pry along the edge of the back case until the back is ready to be removed.
  • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
Hier Übersetzung einfügen
