Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped. On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
  • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
  • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
  • Push the pin into hole until the Disk Drive pops out.
Hier Übersetzung einfügen
