Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 6
On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
  • On the non-camera side of the phone, remove the four 3mm screws and two 2.3mm screws holding down the twist-structure.
  • When you lift this off, you will need to disconnect the cables from the other side using the same method as in step 5.
  • Again, be sure to record which port each cable was in and the orientation they were plugged into each socket.
Hier Übersetzung einfügen
