Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 16 übersetzen
Schritt 16
Kindle Fire Repairability Score: 8 out of 10 (10 is easiest to repair). The rear case is very easy to open, granting trouble-free access to the internals.
  • Kindle Fire Repairability Score: 8 out of 10 (10 is easiest to repair).
  • The rear case is very easy to open, granting trouble-free access to the internals.
  • All the fasteners found inside are Phillips #0 screws—one non-proprietary screwdriver is all you need.
  • The LCD is not fused to the display, making replacement an easy task, if necessary.
  • Simplistic design and limited functionality means fewer components and less headache for disassembly.
  • A decent amount of adhesive is used on the battery and motherboard, meaning some prying and gentle working is required for disassembly.
  • The glass panel is fused to the front plastic frame, meaning a heat gun is required for replacing cracked glass (or you have to replace both components together).
Hier Übersetzung einfügen
