Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
5. Schritt
With the flat end of a spudger, flip up the black flap on the display's ZIF connector. Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector. During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
  • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
  • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
Hier Übersetzung einfügen
