Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • This may be a challenge, so try the following two methods:
  • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
  • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Hier Übersetzung einfügen
