Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 2
Some devices may have a piece of tape or plastic over the ribbon cable latch.  If your device has this, remove it before continuing. Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool. Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
  • Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
  • Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
  • Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
  • Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
Hier Übersetzung einfügen
