Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2 übersetzen
Step 2
Flip the motherboard over and locate the soldered antenna connection. Melt the existing solder with the tip of your soldering iron while gently pulling on the antenna.  The antenna should come off easily. When reassembling your device, attach your new antenna to the motherboard using the two 2.4mm Phillips #00 screws before soldering. This will help to align the parts properly and make them easier to solder.
  • Flip the motherboard over and locate the soldered antenna connection.
  • Melt the existing solder with the tip of your soldering iron while gently pulling on the antenna. The antenna should come off easily.
  • When reassembling your device, attach your new antenna to the motherboard using the two 2.4mm Phillips #00 screws before soldering. This will help to align the parts properly and make them easier to solder.
Hier Übersetzung einfügen
