Zum Hauptinhalt wechseln
Englisch
Deutsch
5. Schritt
Remove the base from the LCD by lifting it upwards. Flip the LCD so that the hinges face you and the screen faces upwards. Remove the two LCD bezel screw pads located in the bottom left and right outer corners by pulling them up and out.
  • Remove the base from the LCD by lifting it upwards.
  • Flip the LCD so that the hinges face you and the screen faces upwards.
  • Remove the two LCD bezel screw pads located in the bottom left and right outer corners by pulling them up and out.
  • Remove the two 4.4 mm Phillips #1 screws located under the screw pads.
  • Pry the two side hinge covers with a plastic spudger and pull them up and away from the LCD.
Hier Übersetzung einfügen
